Ok so i've searched and have done some reading, just want to clear some stuff up.
I would like to beefen up the ass end of my 32 sedan mainly my driveshafts, from what i've read you can stick in a GTR centre into my R200 case then i would be able to use the driveshafts. Would the driveshafts then go into my GTST hubs/bearings or would they need swapping out also?
Are the internal diff centre splines completely different to the GTST's? The GTR halfshafts are 6x1 bolt, mine are 5x1 bolt. Are the GTR driveshafts internal spline(on the end of the bare driveshafts) completely different also?
I know it sounds like a lot of f**king around but i currently have some goodies in the back and my TEINS and KAAZ 2way are only a year old if that.
Or the other option is to get a bare GTR subframe with centre and driveshafts but then can the GTST's arms and watnot be used?
https://www.sau.com.au/forums/topic/337997-r32-rear-subframe/
Hi mate,
I've done this mod, you will need to put the whole GTR diff, shafts and hubs onto your subframe. You will need to use GTR struts and lower arms too, as the GTS-t ones have different mounts. You will also need to put the GTS-t flange on the diff to meet up with your tail shaft.
It's a lot of frigging around but it's well worth doing, the GTR diff is so much better it's not funny.
Bobby.
you can still use gtst suspension. easiest way would be to unbolt the ankle/ knuckle on the gtr hub and bolt on your gtst one. but you do need to use the gtr hub as they have a different number spline.
yes you can use all gtst arms as long as you use the gtst ankle, u dont even need the gtr subframe.
the difference with the lower control arm is that the ball joint that mounts to the ankle is alot wider then the gtst one
Edited by Dan_J
Paul, did you swap in a 33R subframe?
I scored a free R230 (out of a z32) and hopefully some matching axles, will be interesting figuring out how to squeeze it in to the 32gtst subframe.. Should be a decent upgrade if I ever smash what's in there :huh:
Also keen to see how big these axles are, they have the same 6x1 flange as GTR's (don't have a GTR axle handy to measure but the PCD looks the same). If 32R axles bolt up then I may have to source a 32R subframe, if not then maybe z32 hubs or modify the standard ones.
Of course I didn't do it myself, I'm not going to damage my beautiful hands :D
The guys at Xspeed did it for me, from a rear cradle that Gav Beer had.
:P
When you get home (if the car is still at your place), can you have a look and report back whether the half shaft flanges are 5x1 or 6x1 and whether the tailshaft>diff connection is 4 or 6 bolts?
Cheers! :)
  • 6 months later...
Dig up from the past. I have a bare S13 rear non-hicas subframe sitting on my bench at the moment. Looking at it from the rear the front passenger side mount sits approx 4mm up. There looks to be a slight kink in it where it must have taken a hit at some stage.
My question is, Will this affect the alignment settings IF i finish overhauling it and put it in the back of my 32 sedan?
I will be using adjustable arms in the back for everything also.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
