I'll hopefully be making my first driving appearance at the new WSID either this week or next to try and get a 13.8sec (down from 14.46sec) with only: K&N Panel Filter, full 3" exhaust, 7psi and 225/50/16's.
I had a 2.23sec 60ft'r but was plagued with axle tramp. So if I can remove the axle tramp I think I have an easy 0.5sec begging to be wiped.
(honestly though i'd just be happy to get off the botton of the SAU Drag list :O )
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-679268
i know this isnt relevant to the "STOCK" issue but i only had pod, cat back 3 inch, 13psi, 215/50/16 on stock rims and ran [email protected] so its doesnt take much. i got a 2.09 60 foot!!!! but havent been able to beat it even after doing my exhaust from the turbo. best i managed after that was [email protected] 2.28 60 foot. I might go and race this weekend 28/2/04 at the test n tune to try and beat it. Gonna try and raise the suspension up to get some squat. Oh by the way i had my tires let down to 20psi
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-695586
no idea how you guys race with 215's and 225's ive got 255's on my 33 and it still chirps in second and does mad launches. no idea how u make it keep traction with 215's and 225's
stock with only pod, no zorst, stock boost etc.
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-711579
i agree,i have a pod, cat back zorst and 255's and mine wheelspins in second a fair bit (alot larger than a chirp) and chirps third in power shifts (not flat changes)
https://www.sau.com.au/forums/topic/33823-stock-33-times/#findComment-713545
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
