I have a series 1 with a forged RB26 engine and manual box.
Have decided I need an LSD, Question is what will fit ?
Ideally I would like to keep the front as is because changing it is more work than the rear. Ive found an RS FOUR S and can have both diffs if neccessary
Anyone know if the ratios are the same as series 1 cars or indeed if the diffs will even fit .
Thanks in advance for any help.
Can't say for sure but I think they are the same: just under 4.1
I'm going for a GTR diff partly for the thicker axles (and also because the engine is out anyway I can change both). So I guess you haven't snapped any axles yet?!
Not yet but I am going to santa pod next weekend so if anything is going to go it will probably go then.
Main question was whether the RS Four S had GTR diffs as I know it has HICAS . If not then the difffs are probably the same ratio which is good news.
GTR have 6x1 bolt pattern for the half shafts Stagea are 3X2
Be sure to post up your times!
The joys of not owning a RSfour S from the start.lol. Suppose it was afactory option. Going nismo should save quite a few hassles, has a install kit included. I found this helpful when looking into an 1.5 or 2 way lsd option. Part no seem to be the same? Download the installation manual and check diff type -compare (R200/R200V)and final drive ratios. IMO expensive thru nengun but cheaper at jap auctions. btw US is also a good place to buy parts atm.
http://www.nismo.co.jp/en/products/competi...lsd/gt_lsd.html
Edited by dirtyRS4
Going by Jason's handy chart it looks as though most Stageas are 4.083 apart from the manual S2 so if that's what you've got then its a 4.111 viscous lsd - wrong ratio and viscous aren't all that flash either. However if you are happy with the viscous diff then you will need to change front and rear. At least that way if the rear lsd packs up you can get a GTR one (also 4.111) - or other aftermarket lsd - and the front will still be right
Thanks guys
I have just bought the S as a runabout as the current Stagea is no longer a "town car" and I need an estate
A vicous lsd would be an improvement for sure and as its pretty easy to swop and I have both cars I was simply going to swop the rerar diffs over (as long as compatible)
Looks like the diffs are different after all so changing both difffs on both cars is a no no , I will just have to carry on lokin for an lsd for the series 1.
Trouble is finding one in the uk is almost impossible .
Thanks guys
Try ebay - there are some Japanese people advertise there or posibly ebay.au - quite a bit of RB stuff.
So you have the stagea diff/sump on the 26? need to know what your front diff is first then we can advise you of the options
It has standard Series 1 RS Four diffs.
Re the standing 1/4.
Well I said I would post the time so even though it was not what I hoped ...........However this was entirely due to my rubbish driving
It was my first ever attempt on a strip which was pretty obvious Time was 13.09 with a crap start (0-60 ft was 2.5 sec ) And then to make things worse I missed forth gear completely
At 1000ft speed was 106 I missed gear and and went over the line in neutral at 104 mph
so no doubt that the car is very much quicker than me !
My car use to be series 2 auto
I now run a series 2 S manual rear end
According to the nismo chart I have 4.083 in the front and 4.111 in the rear
That's correct. In that case I guess I was mistaken to suggest that the OP has the "wrong ratio" and in fact it will be near enough. According to my calculator that is just over half of one percent difference so I guess the Attessa is capable of overlooking that small difference and the OP will be fine with putting that diff in the rear only.
In my case I have an R33GTR diff to go in the back and i will put one in the front as well because the motor is out anyway and RB26 front diffs are a dime a dozen because people put RB26s into two wheel drive cars all the time.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
