  • Replies 80
funny how your all trying to avoid typing the word GAY what are you afraid if you type it you may realize what you truly are ?????
me personally I'm comfortable with who i am I'm married I'm a father i enjoy regular sex with my wife and i have neons !!!
now I'm sure one day you will become comfortable with your hidden sexuality and finally be happy and not have to worry about what everyone thinks and finally be an individual for once rather than run with the rest of the sheep !!!
Your posts in this thread make you seem very up tight maybe your not telling the truth and your actually not getting any and its all sexual tension?
Is there any gay denial thing going on here. Do you jam yourself with neons maybe?
Just Sayin....
Even if i was ga-.... homo.. at least i'm not installing neons to attract little kids.. (re: your post about reason for neons)
in all seriousness just chill its the interwebz and nothing should be taken seriously - srsly
dude, srsly read this.. i'm stirring you.. i even tell you.. but you still come back.. go to the bathroom.. have a flog.. and calm yourself down.. if you want the ghey neons.. have them.. but really WON'T SOMEONE THINK OF THE CHILDREN
lol and still avoiding the word ???? i sense fear !!!!
I'm not getting shitty i just love these threads because it brings out the stereotypes !! I'm having a little fun mate .
oh and neon not been individual well have you noticed that yes every man and his dog had neons once (they were classed as fully sick you would say)
but as per most fads once everyone had them people started to dislike them because they were so common right ??
now to have neons is actually rare because they were shunned buy the trend setters like you (and every one whats to be like you at least thats what you think )
so technicaly I'm am been individual in a way , sorta like the whole roller blades fad which will unfortunately will come back some day .
as for attracting little kids these are my closest friends kids and when i got the car they asked if it had neons so i got them to make them happy after all my life does not revolve around me ,
ps... i cant wait to see the next thread on 22 inch rims that always gets you all fired up !!!
obvious troll is obvious. you guys are too easily trolld
haha you guys make me laugh! :D maddowse, im with you on this one i just dont want the neons though because nobody hasnt got them ive gone for a different setup in my car with those black light neons they give a good effect not to fond of the coloured neons exceptions are coloured exterior neons but i dont hold it against anyone for modding there cars
happy modding!
happy modding!
if i was on e then your car would be the greatest thing alive LOL
Settle down guys.
Love you..
U said it to Craig... Arrghh the world is now going to end is a massive homo erotic porno scene
your getting me all excited..
ok thats some nice lighting...^^^^
ddoes anyone know how to make interior lights fade on and off, my Navara D40 does it and its kinda nice... Id like my footwells in the 33 to do that, just some subtle lighting not coloured or anything just on door open
i'd assume you'd need to install some sort of dimmer on a relay or something similar.. i'd be asking JayCar about it.. They might have some form of kit if not should be alble to point you in the right direction..
Edited by .:: GimpS-R34 ::.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
