hi
ive been doing abit of research, and it seems like 100cell hi flow cats are the way to go if your running more then average power (300kwatw)
i know there are tons on ebay, but the quality is unknown, ive enquired about the CES 100cell 3" hiflow cat they have on offer and im waiting to hear back about flow/warrenty/etc, has anyone got/used a CES cat before ? how did you find them?
also looked at afew catco metal cat ones from justjap but they are 200cell. how much power can you make with a 200cell 3" cat before you need to upgrade? is there reallllyy that much of a power differnce between a 200cell and 100cell ?
i just want to do it once do it right, dont want to keep changing cats becuase they collapse after afew months, or find they are restricting flow
any helpful information would be good !
thanks
https://www.sau.com.au/forums/topic/338388-upgrading-my-cat/
300rwkw = 4" cat at least.
I cannot see a 3" honeycomb cat flowing enough. I can feel a minor different with my 4" CATCO cat with a 3.5" exhaust/280rwkw.
It's not major, but its noticeable none the less.
I'd be going with a big 4.5" CAT personally having doing it again.
My front pipes merge into 3" collector and my cat back is also 3", can an exhaust place modify a 3.5" or 4" cat down to 3" flanges? That way the internals are huge and flow more ut will fit my system perfect ?
Cheers
hi
Less cells = less surface area for catalyzing = bigger holes. More flow at the expense of less effective catalyzing. At some point the conversion will stop being legal.
I have a metalcat cat (6" body, no idea what the in/outlets are supposed to be but probably 3.5"). I would guess it's 200cell as I don't think they had 100cell then.
For what it's worth it's been under the car for a few years, been through many track days and a couple of intercooler-pipe-blew-off
fireballs that destroyed the car's glasspacked mufflers.
I recently pulled it off the car and while a little black, it seems to be in perfect working order. Can't ask for more than that.
Cheers,
Saliya
Cheers,
Saliya
what sort of power are you making with the 200cell metalcat?
As usual I see lots of confusion on cat sizes.
Most people take "5" cat" as having 5" flanges, me included. Where as people are refering to the actual body of the cat. It could have 2" flanges for all we know.
The body is also important, the larger the body the larger the cell size at a given count. A 5" body with a 200 cell count will flow worse than a 4" body with a 100 cell count etc.
I think people in the know need to be more specific when stating figures with cats.
1 power run @350rwkw before the dyno overheated.
I intend to visit another dyno with a slightly-different setup sometime soon (same cat / similar exhaust).
Will remeasure and repost.
Cheers,
SW
I've got a Xforce "highflow" cat, and i just found out they are 500cpsi... shit!
anyone used one of the ones floating around ebay?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
Yep, i have bought 2 now. Mine is flowing great, not sure about the emissions though. I cut the inlet back to make it 3.5 inch.
should probably make sure it's emissions legal, otherwise you may as well run a decat ;)
They apparently meet euro3 standards, what else can you go by? Stops the smarter cops shoving something up there and finding the hollow pipe I guess.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
