Best Sound?
got a hks hi power on my series 2 r33 i reckon that would sound amazing on a 34 but pretty pricy and highly illegal db wise it stated in the manual (for use in japan only no other country) im assuming its because its the same exhaust they used on most the fast and the furious cars they are designed to spit flames that and the decibels pumped out
Inner Silencer with HKS? Or would it change the note alot?
it would change the note substantially i wouldnt bother with a inner silencer just get a peice of sheet metal the the shape of the exhaust flange if your worries about cops and drill 4-5 holes about 1-2 mm big in it so then if you get hastled in goes the restrictor :down:
I've got the Trust power extreme II on mine as well and it sounds nice, pretty quiet and sounds good when you give it a squirt, it'll get louder when I change the cat and front/dump pipe.
One of the best sounding ones I've heard are the HKS Silent Hi-Power tho.
I have a front pipe, straight pipe with an Apexi N1 exhaust. Sounds ok but just a bit louder than OEM IMO. N1's sounds alot better on SR's, Ill give another report once I change my turbine outlet.
I don't think there is a "best".
haha ok, I heard a GTT passing me while I was sitting in my car and as it passed you could hear the spooling of the turbo through the exhaust, sounded pretty good not sure what exhaust though
i would say you would have heard the turbo through a pod filter.. not the exhaust..
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
