Car looking all nice and shiny!!
OMG, yummmmm!!! Where's the Chaser badge on the front though, Sidd?
Eric, I still haven't looked at the video I took on Sunday, but I'll give it to you Thursday if you're coming out.
  • Replies 407
Posted Images
That looks really col Jay! Only just noticed it now. Did you do the graffiti as well? I assume you did judging by your comments?
Owen - Maybe piss turns glow in the dark when its baked into the paint? Who knows.
Have you checked your oil lately? We may have drained the sump...accidently of course!
Or maybe we stuffed your girlfriend into the fuel tank... But that's a bit far-fetched.
Edited by FST513
She came up to my office this morning so I don't think so :( And uhh, checking oil... no. Only time I check that is when I flush it :)
Blah, I'll figure it out tonight... maybe. Brought my camera to work today with the idea of going and taking some shots in the Uni at lunch; pity it's a shithouse day.
Maybe we flushed it for you? :(
Tip: Use a black light.
Clutch - I think it looks good. Really moody. Maybe you can use a layer mask and brighten the flower up so the yellows pop a bit more?
thats a good idea, i dont know much about photoshop, how do i go about this? and can it be done in lightroom? (i dont have ps installed)
I really should just write a layer mask/adjustment brush tutorial LOL. I've explained this at least 15-20 times haha.
But in summary.
Crank the levels up/curves so the yellows are brighter and poppier.
Down the bottom of the layer palette is a camera look icon. Click this.
Change colour palette to black and white (Shortcut key: D). X changes between primary colour & secondary.
"Paint" in what you want selectively. Or you can press CTRL + I (on PC) or Command I (On mac) and this will invert the mask so it will be your original image still and then you can just paint the flower (Easier for you as you only want to do a little bit of the image not the entire image).
In lightroom:
Go to the develop tab
At the top underneath the histogram, click the brush.
Make sure you choose exposure, paint the flower with the brush. I think its the same in lightroom as PS, to increase brush size is the ] key and the decrease is the [ key.
You can then slide the exposure around once you have found what you want.
You can then paint in extra contrast etc etc...
Hope this helps :(
But in summary.
In lightroom:
Hope this helps :(
cool thanks, will try it out tonight and repost!
Yeah, I had some left over paint in the shed so thought i'd have a go. Ran out of white tho as I only had two 1/4 full cans.
But found a few good pieces to light paint, just got to work out how im going to get there as the skyline is playing up. :'(
Which batteries you talking about? Your box of thieved batteries from work or the ones you took out? The ones you took out you put back in that bag with your 6million year old flashes.
I checked all my bags and i don't have any batteries. If you did lose them - Get eneloops!!!! You'll never be changing after them i tell ya! Recyle time will be SO much faster on your 6million year old flashes. If there not, i'll pay for the eneloops thats how good they are.
Jay - Ahhh ok. I got a question for you. Obviously graffiti isn't done in publicly lit streets (Well pieces like yours). Do you go out to these random places by yourself and do you ever sh!t yourself??? Some places look so dodgy!!! I'd be sh!tting myself!!!!!
I'll only buy you some Sidd if your energizer batteries are faster than eneloops :down:
You can buy them at dick smith or online. I think its about $30 for a 4 pack. Buy two packs of them and it'll be the best $60 you ever invested!!!!!
Oh and where was your battery pack for the wedding on the weekend, i forgot to have a look at it.
they look dodgy, but most times i've been there during the day and that makes them feel pretty safe for some weird reason. i consider the tunnels the safest as its not that likely that you'll run into anyone. i guess i dont really think about it much.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
