Hey,
Im in the market for an R34, but i havent driven one yet. I'd rather waste a car dealers time test driving one than a private sellers. So far i havent been able to find one at a yard... Or any import yards for that matter. I know there are a few in coburg and around that area but i cant rember the name, or find them in the yellow pages.
Anyone know of any? I'm trying to find a stock manual, so i know what the base model is... then ill buy something better.
Im in boronia, so i wanna check they have them in stock before driving all over the city looking for one.
cheers y'all
https://www.sau.com.au/forums/topic/339649-car-yards-melbourne-that-have-r34s/
what eva u do dont go to the place on bell street preston jsa or msa whateva it is
i bought my 34 from jap cars in fawkner, i highly recomend him his name is dennis, a few of the sau boys have got there cars from him also.
Hey James. Sorry mate but I think SEI motors have the worst condition cars I have ever seen. They import garbage and fix it up in aus. Do not buy a car from them. They are dodgy f**ks. A lot of people will agree with ne about them.
guess i must of picked the lucky ones, bought a 33 s2 na had it for 2 years not 1 problem, gave it hell. and now this 33, had it for over a year no problems either apart from common stuff coil packs etc
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
