  • 4 weeks later...
Yes but this is a full on resto. Very little expensive spared on it over the past few years. Still a lot of small things to buy.
I have 15-20k in parts alone sitting on a shelf in boxes. All new.
Show us yours.
Ordered some more interior trim today. This is another 4 figure sum in NOS parts.
Nissan still make the interior panels on demand. Good for now so I am getting a set before They go NLA.
Which bits?
Door and rear panels. I have a decent secondhand set here as well. $2.3k for all 4 items. Door panels are fully dressed and ready to fit.
Small hardware is SUPPOSED to be with them. Unsure at this point. Going to replace the hinges as well. Yet to check those.
Once these land I am going to do more internal trim. I have most of this already but need a few more bits still.
One thing I still need to check is the boot seal and its availability .
Build looks amazing, can't wait to see this finished.
I haven't read every page so I'm sorry if its already been asked, but what are your plans for the car once finished? Are you doing a basic full resto or are you adding performance bits along the way?
It is for my daughter, car is a resto with some changes. Engine will get a freshen up and a flex fuel conversion . Car will be plenty quick in stock form.
  • 4 weeks later...
  • 1 month later...
trim stuff arrived a few days back. ordered a new set of front indicators for it locally on friday. should be here in a few days.
spoke to CDR paint and panel (local club sponsor) about reassembling the body. roughly $11k to do it. I 'm not holding them to it as there is a fair bit to do that they did not see from the images. waiting on a few things to fall in place at the shop before I commit to that amount of money.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
