  • Replies 117
Sorry guys but I also had a UHF and was calling out warnings from the front of the pack, but we got split up too early.
But guys please invest in an UHF radio if you are coming cruising, saves so much heartache and time.
UHF's are good.... what sort of UHF do u have nexus ?? I am not sure how far ahead you were from me, but it was a bit crackly... i have a uniden with the taller aerial (about $100), never had any worries with it, but i couldnt get much out of it last nite....
Later runs thru the hills is better too... less traffic = more safety
My Bad, I think the batteries were running flat so it wasn't giving the range it is meant to.
Oh and it is the $100.00 Uniden too.
The thing with those $100 pair CB's is that they only go for 3k's(eye sight distance) , some better ones go for 5k's, would that work if you're stuck somewhere in the mpuntains and all the rest have done a "Schumacher" on ya.
this CB is a 4watts 4miles
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...&category=40055
i was inside maccas yoparata, u think i'm gonna stand outside in the heat and watch everyone inside in the air con! :mad:
I was wearing a white shirt and a black nismo cap, cops told us to move bout 11ish. I saw a heap of skylines come in with tyre select written on em, was that u?
Fine I give up, dont know why but it just is not co-operating, please find all my pics I got, well those digital, have not processed the film ones yet, but anyway fine them all here for the time being until I can figure out why I cant upload them here....
EDIT: Strutto kindly has uploaded them to his user area here BIG THANKS!
http://www.skylinesaustralia.com/members/strutto/ngc/
didnt get a chance to say thanks, as i went caming just after work on friday, but yes thanks, i had an awesome time, struggled to keep up a few times but i got there, MJ dont complain u got snail power.
cheers
John
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
