Hi everyone,
Last year at a car show we got our R33 dynoed with the following mods,
hks bov, cat back 3" fujitsubo exhaust system, turbo smart boost controller (red one), blitz sus pod filter and 12 psi on stock turbo, ecu and intercooler.
At that time we had the problem of a miss fire because of the spark plugs not gaped to .7 so it was missing on the dyno but we still got
162rwkw on a hot day. we also had a slipping clutch
Tomorrow were taking it in again on the same dyno to see what we have gained.
the list below are the mods that we have added to the top.
Heavy duty clutch, 3" dump pipe, FMIC, high flow cat, 14psi of boost. - we have reset the ecu after installing all of these mods.
i'll post the dyno graphs tomorrow.
What do you guys/girls expect i would get with these new mods ?
https://www.sau.com.au/forums/topic/33987-r33-gts-t-dyno-graph/
I think you would be doing well to get 180+ rwkw (241rwhp)
Different dyno's will give different readouts (as I have found out over the last 18mths).
Edit: '95 S1 w/ 85,000km.
For me (in order):
(Unigroup)
* FMIC
* HKS Pod
* Daiken Exedy Organic Sports Clutch
* Nismo Cat-back
* 12psi
* Stock Turbo
* Stock ECU
= 192rwkw (257rwhp)
(Unigroup)
* FMIC
* HKS Pod
* Custom 3" Front/dump + 3" Cat
* Nismo Cat-back
* 12psi
* Stock Turbo
* Stock ECU
= 203rwkw (272rwhp)
(Unknown at Western Sydney)
* FMIC
* HKS Pod
* Nismo Cat-back
* 12psi
* Stock Turbo
* Stock ECU
= 186rwkw (249rwhp)
(Croydon Racing Development)
* FMIC
* HKS Pod
* Nismo Cat-back
* Bosch 040 Fuel Pump
* 12psi
* Stock Turbo
* Stock ECU
= 180rwkw (241rwhp)
So as you can see different dyno's and different days (the above UniGroup days were both 30+) certainly make a difference. I certainly noticed a "seat of the pants difference" between #1 and #2 and also #3 and #4 (no mods were done between #2 and #3) but the Dyno's didn't show this.
As Benm was saying, it's too hard to 'guess' what power your going to get cause every dyno is different.
The important thing is that you get a gain.
I would take your old dyno print out along when you do the new run and then compare the two graphs (as long as it's done on the same dyno).
Just as a comparison (for what it's worth), mine has pretty much the same mods as yours but at 12psi and did a 169rwkw.
Again, it's all about getting a gain on the last run, and also, outright power isn't everything. I only gained about 10rwkw at maximum power, but I managed to get rid of the flat spot in the mid range. Getting rid of that gained me about 34rwkw in the mid range !!!
J
Hey just got back from the dyno and it was done on the same dyno as last time (shoot-out mode).
I'll post the graph tonight.
We got a max of 184.5rwkw's (247.4hp at rear wheels) on the last run. that was with some more boost. but the a/f ratios were going stupid.
With the last run we were running 14.5psi which the a/f ratios were leaning right out to 30.0 which isent good. but on 12psi we got a/f ratios of 12.4 so we left the boost on 12 intill we can get bigger fuel pump and injectors. if thats the problem?
We are pretty happy with the results going from 162rwkw's to 184.5 rwkw's just in (front mount, 3" dumpie.) and in a month or 2 were gonig to bolt on a bigger turbo and do fuel pump and so on and chuck it back on the dyno ;)
we noting trying for power we were just seing what the difference in mods made to the car.
unfortunaly we live 4hr's away from the nearest track so its not every week we can make it out their.
with the first list of mods in my first post (with out the miss firing as we fixed it) we got a 14.1 pass on the quarter at 103mph on street tires. but we had a really really bad slipping clutch.
So were going to take it down again next month and see what the outcome is. were hoping for a high 13 or better ;)
i wouldnt put on the turbo yet, id concertrate on upping the torque low down, do the turbo later, check out some of syneykid's posts on what else you can do before the turbo
i wouldnt run 14psi without some form of fuel control, even without an safc, probably 12psi max
your just asking for shit to go bang :cheers: - this explains why yours a/f's = psycho
just cos you are seeing more power at 14psi doesnt mean its good power, probably doing damage than good
you'll probably loose power adding more boost as the ecu corrects the timing and stuff so it doesn't go bang.
im no expert but this is what i've learnt anyway
agreed that dyno figures can be somewhat misleading but i believe you can get a rough estimate from a dyno graph, and thus, they are a tuning tool - i wouldnt class them as being an accurate reader of power.
comments about track times are abit more valid however i wanted to say that an ET is sometimes pointless aswell. the best indicator of power is the terminal speed.
fwiw, i have recorded a 199.5rwkw on c&v's dynodynamics dyno. ran a 13.8s ET with a 2.1sec 60ft and 99mph terminal speed. goes to show that the car was tuned for mid-range...
mods are as follows:
-powerfc
-avcr @ 0.8bar
-fmic
-full exhaust
-stock airbox with hiflow air filter
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
    • Haha good old Letterkenny! If you're looking for another great english canadian comedy, I strongly recommend Trailer Park Boys.
    • I live in a French European province, within a very metric country. We hate football here and the statue of liberty was actually built in France haha. Sadly, we're currently also feuding hard with the US due to tariffs. The US is the US. Everywhere else, is everywhere else.
    • Heater wasn’t working in my 32  so I decided to pull my dash out ( sounded like a great idea at the time) so initially I was sure the heater core was blocked. When I pulled it out turns out that the heater blower actuator was cable tied so it stayed shut and this prevented the heater core from doing its job as well as flowing. so currently the dash is out the heater core is out and seems to be fine but I think I’m in over my head  and need someone that knows what they are doing to take over and get it finished. I’m located in mt Annan, nsw 2567 if anyone has any ideas or suggestions please let me know
