  • Replies 165
No biggie, but I dont remember buying a GTST?........ :(
sure ya did... remember... it's purple and has a GTR bosykit on it. seems to launch very well for a 2wd tho
I hear GTRs handle like a boat on the front end on the tight skidpan :s I shall find out soon!.. if so.. nothing a few clutch kicks cant fix aye!
just watch femno out there in his R and say that.... :)
woot
faxed forms and paid for.
BUT i just realised my AASA licence expires on the 16 of november :( i can renew this on the day??? and my mate is entering who dosnt have a AASA licence he can get one on the day as well???
woot
Contact AASA and sort your renewal out beforhand if possible. your mate can sign up for one on the day.
Re jfk, yes you can pay for entry and membership together. If you have not got a licence then you can get it on the day. Bring exact monies please :)
thanks for the replies guys...didnt know how this works...so just wanted to make sure i look into it when the results are up...geezz didnt think it will get confirmed that quickly...well organised.. :(
thanks ryan :) will call up and renew now. even though the form has my old exp date will that matter???
They should give you a new one. It's over a month away! Plenty of time.
These people have sent me entries with nothing in the licence section:
Daniel Robson
Steven Skrekovski
Tony Skrekovski
Jack Kuzior
Ash Cosgriff
David Lee
Edwina Andrews
David Church
Srete Cvetkoski
Glynn Matthews
Please print off the form from the link below, fill it out 100% and either send it to AASA bring it to sign in with exact money please.
Anybody who does not have a licence can do this.
AASA Club Racing Licence
The people below have licences that will expire before the event. Please make sure they are renewed BEFORE the event.
Vince Ritchie
Tom Giordano
Ashneel Prusad
This is all to save time at sign in.
5 Spots left!
The cheese eating, surrender monkey and me are entered. After the last DECA i think its time i bolt the front brakes back on....running bigger rears then fronts made it an interesting car to try and stop :)
Edited by Roy
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
