  • Replies 50
Mark from SSV was driving it for awhile before this was put up for sale. It's already in their yard when I bought my V35 off them in May. I used to go there once or twice a week to check the progress of my car for about a little over a month. So I have seen it in flesh many times. All I can say is overall it's a pretty straight R34 GTR. No major dents or marks. Engine looks ok with some minor mods. Sounds awesome too. 55k is on the high side but their cars are usually pretty neat. So they might have their reasons to justify the price.
P.S. If they tell you the Ks are genuine, don't believe them cuz Mark himself told me they are not. :blush:
LOLOLOL ...... WOW, you'll be popular.
It is a V-Spec model + the interior looks decent for it's age, but if K's are "wound back" then fuck paying $55K for it.
Either ask for a lower price or go else where...
i bought my R34 from them and i wont recommend anyone to go there they dodgy
parts has come off that car cos i remember he tried to swap my HKS exhaust for the Apexi N1 that was in the Gtr.
first two days i bought my car, my manifold cracked, i told him about the noise before i bought the car he told me it was exhaust noise
i bought my car back in may when interfoiler bought his :), its been sitting there since then and the price was around 60k mark
i had a look at that caryard before i bought mine, and i remember asking about that blue gtr n the guy replied its my brothers (the owners) and i bought my car aug 09 so u can imagine how long its been sitting there
in terms of price, you can find for sale locally '99 GTR V-specs for 40 - $45k.... and i've seen 34 GTR's be imported for as low as $33k!
this one is in Vic, $42k
http://www.carsales.com.au/all-cars/privat...mode%20matchany
Yes, local ones seem cheaper than imports, but I really want a blue R34 :ninja:
Import for $33k? Where? Most cars from Jap Auctions go for easily over 2.5M yen and that's at least $45k+ landed, complianced + ORC.
It really depends on the auction. I did see someone import VSPEC2 34 on road for under 40K...its the game of luck...
Just ask Aaron at import monster... he imported a white R34 GTR 99 non-vspec which ended up owing him only $36k from memory
YES he did tell me that....that another lucky one got a great car for a bargain...
