  • Replies 206
you'll want to swap the diffs back if your after more acceleration.
auto- 3.9-1
Manual - 3.7-1
or, if you can find them, pintara pinion and crown wheel for 4.1-1 ratio
and with the speedo issue, the 31s and 33s both have electronic speedos. you need a Speedo Interceptor (jaycar sell them) and the just adjust it using a navman or something.
will get the pics soon. all depends on if i can sum up some motivation and walk downstairs, move the car, jack it up and then roll around in crap.
as far as i know oil lines run from turbo to engine with a oil pump to assist.
i have a separate oil cooler for the trans.
i've sourced a r31 skyline diff with lsd. and i believe thats a 4.11? and i think the pinny's have 4.1
i could be wrong. and just so i know, the bigger the ratio the better acceleration, ie 4.11 is better then 3.7?
cheers
cheers
4.11 will get you better take off and higher cruising rpm's, 3.7 will give you better top speed and lower cruising rpm's
ah thank you. i'm looking for take off as i care not for my fuel consumption.
does any one have any thoughts on installing an r33 auto gearbox. i was put under the impression today that they'll handle more power then an r33 manual box.
cheers
Kurt
cheers
Kurt
Manual is much stronger till you spend a few Grand on the auto, would definately be stronger than a 31 auto tho
If i was you i would try to keep it auto, a friend had a 5 speed turbo 31 and he changed to an auto with a hi stall and the thing was awesome, there not the best handling things till you start putting S13 struts and brakes on em so you would be better of with the auto for straight line speed and a small amount of twisty action.
yeah i want to keep it auto. already have a stall convertor. My next step is the r33 auto box and lsd. Then a full s13 suspension conversion along with break upgrade (something like r33gtr or gtst breaks, the four piston ones) and fatter tires with good tires. then after that more engine performance.
best way to tell what ratio you have is to pull the back cover off the diff before you install it and see whats stamped on the crownwheel. i think 4.11s are 37:9
manual 31 skylines are 3.7 factory (except gts)
auto 31 skylines are 3.9 factory
and all 31 pintaras are 4.11 factory, also 25 spline centre and axles instead of the 28 spline the skylines got.
and only the silo's and gts's came with lsd's, shit ones at that
im getting the lsd for about 70 big ones so im not fussed, its gotta be better then what i got. but i will have a look at it before i buy it. what tools are needed to remover the back cover? and will shit, ie oil, pour out?
and i'm looking for 37:9 to be stamped?
just a socket, ratchet and possibly a flathead screwdriver to pry it off. cant remember what size bolts they are, probably 12 or 14mm.
unless its been drained it'll be full of oil, if you sit the diff so the back cover is pointing up then it wont piss out. yer your looking for a ratio stamped on it like 37:9, or you can count the teeth on the crownwheel and the teeth on the pinion and figure it out that way.
Holdens are much the same of that era, most VL and R31 ppl dont bother trying to chase an lsd because the power of the turbo will kill it any way, my mates had a mini spool (locked) diff, was easy to drive in wet and dry and mega predictable when having some fun.
cheers. Disregarding money then what would be the best diff to get then? and then regarding money, what would be the best diff to get?
and here's some pictures for ya's:
STS Setup:
Engine Bay:
There ya go. Threw in the engine bay pics so ya can let me know how sleeper it looks. I'm thinking if a cop or someone uneducated were to look at that at night they wouldn't no any better?
cheers and once again sorry for the wait.
Kurt
I think you have more of a chance of being defected on suspicion, after all the intake pipe is coming from where it normally would if it had a turbo on it, and if you get some one who decides to trace the pipe (all cops carry torch's day and night) then your getting an epa, to make it stealth you really needed to tell your mechanic to put in the extra work when he put it in, about the only way you could possibly hide it, atleast partially, is to chrome the intake pipe to about 3/4 of the way down the engine bay and from there on paint it matt black, get a pod filter and make enough of a hole down the middle that you can slide it over the the pipe far enough that the chrome ends under the pod filter, hopefully that way all they see is a chrome pipe with a pod filter on the end of it and the rest of the matt black painted pipe will not catch there eye past the chrome.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
