hey there still havin problems with my rb20det it starts up but as soon as it starts it backfires and then shuts down i have change plugs, cas i was wonderin if it had hydrolic lifters inside of engine thanx
sounds like what happened to me a few weeks back, check afm is pluged in properly
air flow meter. it will be ither half unpluged or stuffed. resomly common fault.
and yes the engine does have hydrolic lifters but that wont cause your problem.
and if you have a pod filter hanging off your AFM and its just flopping around like 90% of r32 than that will help in the fatuge of the AFM
Edited by DJRIFT
would all this cause the compression to be at 30psi? thanx for the help
I would think that basically you don't have any rings left. (bent valves generally give zero compression).
Time for a rebuild (or replacement).
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
