Ok guys, I got my copy today. Seller placed a different cover over the mk9 one (underworld evolution movie). The game was completely sealed too :)
Only took 7 days to arrive also due to the fact that easter was delaying everything.
  • Replies 146
Fkn awesome. I can't wait to get my copy. Too bad I won't be able to play you guys online anytime soon...
Can you PM me who you bought it off? Do they have xbox version also or just ps3?
bahahaha..
Game arrived today. Had it sitting at the front door. Yes, that's right, the post office card telling me that no one was home and so I have to pick it up tomorrow after work.
Where you will immediately be arrested for killing young babies and corrupting the minds of the innocent..
So, it turned out that the package that arrived the other day was another item I completely forgot about and not MK.
Not to worry, MK actually arrived today. It was declared as a "DVD movie". I haven't opened it yet to see if there was another cover over it but my mate who bought it off the same guy said that the cover was an MK cover.
Basically guys, game got through no problem. Let the FATALITIES begin. Mind you, the send date says April 19th - meaning that the Easter break DID stall its arrival...
good to hear you got it mate... and that others have got it too with problems.. i hating waiting on the mail i dont have the patients haha
banning the game has just made it inconvienent..
Tag team is quite fun too. Brother and I teamed up and smahed it... on medium... looking forward to playing online - whenever that may be.
So much shit to unlock. even 2nd and stage fatalities have to be unlocked.
Story mode is really cool - destroys the old konquest mode.
For some reason though, the graphics look average during cutscenes but awesome during actual play...
That's what I thought too but it's not the case. If you do story mode, you can easily notice when it swaps from awesome graphics at the end of a fight to shitty looking cut scenes. Even though the game engine is used, the cut scenes have a fuzzy, blurry look to them.
I'm thinking maybe it's the compression method used in the videos. God of war 3 had video files obtained from the ingame engine, although it was nowhere near as noticeable as mk.
I'm just saying. Doesn't change the fact that it's still an EPIC game.
I have to definitely agree on that regarding ordinary graphical cut scenes as compared to the actual fights. Love challenge tower and so much things to unlock. Apparantly there are babilites to unlock as well but haven't unlocked any of those as yet if it's true.
Completing story mode was a lot of fun and you get drawn more and more as you play.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
