"dimple" Neodymium Magnetic Sump Plug Group Buy!
  • Replies 200
I'm just making payment to them now so at a rough guess maybe 2 weeks time give or take. Since this is the first time dealing with this supplier I don't know how long their processing/shipping takes. Could be a lot quicker though :)
Hahahaha yeah my damn group buys seem to fill very quickly :P
Just to confirm, payment for the first batch of 35 plugs was made yesterday and they are getting the order ready to ship once payment has cleared.
Every one will end up getting one in the next batch, don't worry :D
how much did you sell them for??? also can you do another group buy????
and how does it take to recieve them???
thanks heaps
Hahahaha yeah my damn group buys seem to fill very quickly :)
Every one will end up getting one in the next batch, don't worry :)
Hey buddy, have a quick read through the entire thread and you will understand everything that is going on.
To sum it up I didn't think they would be as popular and obviously the numbers involved is very high so we will do batch orders.
The first batch of 35 has just been paid for and once it has arrived and every one is happy we will do the next batch.
You can find most of the details on the first page.
Cheers
Phil
Edited by PM-R33
Good to hear Phil!
Yes, if the GB and diff turn out to be the same size, I'll be in for another 2 myself come next batch :)
These things went like fking hot cakes.
Or just buy a Neodymium Magnet locally and whack it on your oil filter.
They are so damn strong and could then be transferred to any car
They make them aswell :D
http://www.drainplugmagnets.com/blackhole6packfilter.php
UPDATE
Tracking number has been receieved. It is coming by USPS First Class so might be here pretty quick!
First Class eh.. *pulls out Monocle*
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
