Hello!
Im planning to buy a turbo kit for my R33 GTR from Powerhouse Racing
My internals are simple HKS 2.8L Stroker with bearings, ARP rods, new greddt headgasket
Will it hold för 600-700whp?
Well i was going for the T88 but on the PHR site i found 2 other turbo kits t78-t88 and a new one called TD05.
So as i said im looking for a turbo that can handle 700hp but i will probably go for 650whp or something like that.
Will my engine hold? and do i need to spend much more for a good engine?
T04Z and 2 bar of boost will get you there.
I heard thats a good turbo, Will my engine hold? I am gonna leave the engine for some inspection but i want to know what you guys say.
Thanks for the fast answer!
If the engine was properly assembled and balanced, and its tuned properly, you should have no problem sustaining the sort of power levels you are talking about provided you select the right turbo and have all the supporting fuel/cooling/oiling systems in place.
Thanks know im feeling better knowing my engine will hold :D
thats the same set-up as me 2.8L TO4Z .84 garret 710awhp, is absolutely nuts :) scared the shit out of a few mates..
also considering the GT4088R check that out, I went the TO4 because is was tried and proved, plenty of dyno results to look at..
Oh nice mate, Can you put up some dyno results? You drive the car on the weekends or every day?
Will your engine hold? dont bet on it, and for how long, many have failed.
Good luck, I hope it works out.
It wont fail if you have a good tune i knew a guy wich had 600hp on stock engine he started the car a year ago and its still running, He had an awsome tuner.
Not trying to put you off but there's not much info in your threads, 2 bar, 650 to 700hp is a lot of strain and mumbo! how many kms on the engine, who built it, how much work has it done? The tune is one thing but the engine clearances, tolerances and ware is another thing on an already built engine.
The last time I had my engine inspected it involved pulling the engine out and inspecting a big end bearing, sadly they were all f#$&ed after 2000kms.
Hopefully all goes well, but asking if your engine will hold is like asking how longs a piece of stringl. Good luck!
Its the last post in the RB26 dyno results.. not a daily but more than just weekends..
as for will it last, yeah how long is a piece of string, you see some guys putting a lot through stock engines and others breaking built ones ??
you would hope if they have gone to the trouble and expense of the stroker it would be done properly..
no point living life thinking what if ..
just take it up slowly and see if anything comes up (or out) :P
22-24psi should see you around 600whp
Edited by tricstar
No point living life thinking what if.. But definitley worth considering, my comments are based on the guy having made only 12 post and having asked the question more than once if the engine will last, having an already built engine (God knows who built it or what its been through), I suspect he is new to the wonderfull world of GTR's so just some words of caution.
"You see some guys putting a lot through stock engines and others breaking new ones" This is very true. (without rubbishing any engine builders)
Based on the limited information 2 bar would be risky without knowing more, maybe the straw that breaks the camels back, I've had 4 engines in my car (pisses me right off) and used to run 25psi with tomei cams, motec, 2871-10 turbos and many other goodies, these days I run 20psi, smaller turbos, std cams shafts and have never looked back. (my choice only)
22-24psi sounds more realistic, 600whp, still bloody fast.
just take it up slowly and see if anything comes up (or out) :)
Your results are on a hub dyno though are they not?
Well yeah im new to GTRs and the engine is Built by MGT Racing before it reached me in Sweden, I put on some GT-RS turbos and i had the car for 4 months now and run 500hp with no problem at all MGT said that the car was built to do more than that and GT-RS turbos was nothing for it, And ive had 700hp volvos before so im not new into engines and i can handle a car at 700hp.
I leave the engine for inspection tomorrow to one of Swedens best tuners/engine builders lets see what they say
Oh, i forgot to say its an N1 block :)
btw i came in to the forums this year and i barley used it you cant judge me buy looking at my posts.
Edited by SKYGTRONE
yeah,, I had it tuned before on a rear wheel dyno only weeks before, and made 550rwhp , then on the awhp hub dyno only made 520awhp, on the same tune...
after retune made 710awhp ,,
was hitting boost cut on cool nights @28psi . so have pulled the boost back 1.5psi so maybe 680awhp (on a hub) what ever that is? is it a percentage less??
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
