i know this is not my thread but since we are on this subject........
I dont think i have the same problem as Willis because my car is pretty new with no or little wear .
I took my GTR R34 non VSPEC out on to country roads for the first time today and realised i was getting, mid corner weight shift putting the car off line ?
Its almost like the Hicas is kicking in about 80kms and darting the car around on long sweeping bends
The other thing i can think of from this thread is wheel alignment .
Also another thing to think about is the suspension on the Non VSPEC is pretty soft
Any help would be good . Thanks
I think 80kph IS the cut-in speed for the HICAS? Reason people disable it...
Hey mate my R32 GTR got the same problem like urs, after i changed the inner and outer ball joints everything was fixed.
Go to nissan and get it inner ball joint was about 113 AUD forgot about the outer one.
GOOD LUCK dont worry!!!! easy fix!!!
Awesome, glad you got your issue fixed. Thanks for your input! :)
Ok well abit of an update. Upon driving my car to Brisbane from Wagga Wagga NSW for my Christmas holidays i noticed that my steering issue is worse.
A mate and myself jacked her up and pulled the wheels off the fronts, to have abit of a look and see if we can see anything that looked out of place. First check we did was grabbing the brake rotor and gave it a good wiggle. I would have to say it had between 3 and 7mm of play .. indicating that the upper ball joint / something in that general area was completely rooted. As far as i know there is supposed to be ZERO play.
We also checked the otherside, there was a tiny bit of play there as well but no-where near as much. It all makes seems to make sense to me, the RH ball joint had the most play .. and my steering issue was when turning left. The RH side would load up under the weight of the car pushing outwards, and at a certain point the force would be great enough to allow the wheel / rotor / ball joint to "shift / play" mid-courner .. increasing the amount of camber on the outer wheel resulting in an increase of the already instructed turn.
I'm not sure if that is entirely correct (feel free to correct me) however i think it explains my cournering issue perfectly. I had to leave my car in Brisbane though due to the floods, so i won't be able to get the ball joint fixed for another 2 months or so to confirm my prognosis. But i thought i'd update this thread to let anyone else who has similar issue's know what / where to check :)
Thanks BWRGTR, as your suggestion was dead on.
I just diddn't think it would have been something so obvious.. my mechanic couldn't find it (isn't it the first thing to check, play in the rotor / wheel that is) .. so i think from now on i'll try and fault find my own problems!
Hope this helps.
Willis.
If you had the wheels off, and you grabbed the brake rotor, it WILL move around.
The wheel holds the brake rotor tight. Sometimes they lock on nice and tight to the studs (Your left hand side) other times they near on fall off.
Try and shake it around with the wheel bolted on tight.
G'day mate!
Yes we did that as well. Not just the brake rotor moves around, everything does. Something is defintly wrong ;) And also my rotor is locked on to my studs perfectly, no play between the studs and the rotor itself!
Perhaps i should have been more specific. Cheers tho! :)
Willis.
Willis, it sounds to me as though you have front hub/wheel bearing issues.
When you were able to check the free play, was it only horizontal, only vertical or in all directions?
Horizontal only play would indicate steering/tie rods, vertical play only could indicate ball joints/bushes and if theplay was in all directions, I would think could only be caused by hubs/wheel bearings or more unlikely all of the above.
Hope this helps, Tony
P.S. if it is hubs/wheel bearings I would'nt be driving that car more than you absolutely have to.(5km maybe?)
To have a hub fail (if thats what it is) while moving would be very dangerous to you, anyone near you and to your car.
P.S.S. Can't believe your mechanic couldn't find this! Might be time for a new mechanic.
Edited by Tony Brown
willis, check your steering rack mount bushes. you get this problem like you describe when the rack mount bushes are worn as the rack slides in it's mounts creating strange steering problems. could also be toe settings (get the alingment re-checked and find out what everything is set to), or could be stuffed ball joints or tie rod ends. you really need a suspension specialist to have a good look under the front end. the free play in the front suggests wheel bearings but could be a number of things. just get it checked by a professional asap.
well this sounds like my problem. but ive got more of a floating issue even on a straight. you start to feel it about 60km and gets to a point where at 110, youll be driving along and all of a sudden youll be in lane one, then bang lane two.
i have replaced:
bilstein coil overs all round, new brake rotors, pads, hubs & bearings, wheels, tyres, rack bushes, lower control arms and bushes, rack ends, tie rod ends, adjustable castor rods, front sub frame. and thats just for the front of the car.
as for the rear:
still have the HICAS as it has not given me problems. nolothene rear subframe bushes, yes i have IRS and a nolothene diff hanger from Z31parts.com.
i think my next card will be pedders.
Cheers, will do. I think i'll just take it to pedders and get them to tell me what's wrong, then go elsewhere to get it repaired? Most people don't like pedders :P
The crummy Pedders places cop all the flack - and deservedly so. This puts their reputation into a bad light.
Some franchisee owners (eg an Exec of Lower Blue Mtns Christian Car Club) however, are absolutely superb; but the store owner can be wading against a tide of stereotyping.
  • 1 month later...
Alright so i've now confirmed finally that my issue lies in the "Inner and Outer" Ball joints. I do however need some advice, upon speaking to a Nissan parts dude today.. he told me that on the imports BNR32 there is only a lower ball joint and the upper is called a "king pin" .. does this sound correct? Can anyone confirm that these are the 2 parts i require.
This is the first i've heard of the "king pin" as everyone seem to refer to inner and outer or upper and lower ball joints. (after searching SAU)
Any info or advice would be greatly appreciated!
  • 4 weeks later...
Ok i've fixed the issue. Replaced the inner lower control arm ball joint and it's all sweet now. Now to replace more worn out bits and keep improving the old girl :D Thanks for all your help guys :)
  • 3 weeks later...
  • 1 month later...
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
