  • Replies 54
Posted Images
pm sent regarding headlights and coilovers
do you have a pic of the coilovers and keen to post to
perth?
may grap a few other bits also depending on postage costs
cheers
perth?
cheers
will take some close ups, postage no issue. (will use mainfreight)
hey trent, still have the 5 stud? after winton i realised how bad i need to upgrade :S
yeah still have it.
Is the oil cooler kit still for sale? Does it come with everything? Relocater, core, lines n fittings etc? I'll take it if that's the case.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
