WRECKING R32 GTS plus a few other parts here and there some will suit s13's
alot of the parts are in good nik but if u have any questions about the condition of any parts ask and ill give you a run down of how the part is
im located in logan area brisbane qld prices do not include postage
any questions call me on 0432 744 627 or a text would be better =). send a text for any pics
genuine Uras front bar $250
genuine Uras rear bar $200
genuine Uras side skirts $150
genuine Uras F/G fenders $150
Gts front bar (needs some attention) $50
Gts rear bar $50
Gts standard fenders $50
Front r/h indicator $50
Mirrors l/h + r/h with loom (no mirrors in them) $100
Front head lights both sides $200
l/h + R/H doors with glass and motor intact $120 ea
boot lid $ 80
bonnet $80
rear qauter glass both sides $80
suroof with intact glass $200
Rb20de motor and gear box working perfect $1500
Radiator $ 50
Fan shroud $30
AFM $50
Radiator Reservoir tank $20
Windscreen washer tank $20
Rear windscreen wiper motor with stripped bolt (crc and some elbow grease will see it like brand new) $30
Engine and gear box mounts $ 30 ea
Standard ecu $60
Power steering rack $80
Height and dampener adjustable greedy coilovers with greddy in cabin dampner control unit perfect order (done maybe 5 -kms if that) control unit never fitted still in box $ 1800
bilstein shocks excellent condition $ 400
4 stud standard wheels 15' inch with fairly bad tires would recommend getting new tires $300
Multistud advanti race project wheels 17x8.0 x2 17x8.5 x2 geat looking, performing wheel (NEVER used) -still in box comes with nuts and center caps $1200
Front and rear Brakes( in perfect order )$ 300
Upper control arms $ 40 ea
Lower control arms $40 ea
Knuckles $ 150 for front
Driveshafts $40 ea
Tail shaft $ 80
Diff centre or hole diff $ 300
Blitz racing brake pads brand new still in box valued at 400 selling $200
Standard rotors plenty of mil on them $150 for all
Both side door trims $50
Rear qauter trims $50
Front seats $ 200
Rear seats $150
Bride gias low max II reclinable seats (universal rails) little scratch from moving but never used $ 1200
Centre console $40
Dash with no vents$ 80
Speedo cluster
Cluster surround (slight crack hardly noticeable) $30
Climate control console $100
Glove box $30
Momo steering wheel $40
Old crappy sterring wheel think its autotchnica $15
Boss kit $ 30
Drift carbon gear knob with extra fittings $15
Sunroof control panel $ 30
Pillar plastics $15 ea
All foot petals (manual) $ 50
Kick panles $30
Gear stick and hand brake boots brand new in box (black leather) $ 30
Jvc flip out 7 inch slave screen $ 60
Sterring wheel surround $30
Seat belts $ 200
Driving flip down sun shade things $20 ea
Gts rear bar $50
boot lid $ 80
bonnet $80
Radiator $ 50
Fan shroud $30
AFM $50
Standard ecu $60
Driveshafts $40 ea
Tail shaft $ 80
Front seats $ 200
Rear seats $150
Centre console $40
Speedo cluster
Glove box $30
Boss kit $ 30
Kick panles $30
Seat belts $ 200
most prices are negotiable
is the box auto or manual? and how many KMs has it done?
its manual and its done 140,000
though its pretty much perfect doesnt slip clutch is fine no problems that i could find when driving
Gts rear bar $50
boot lid $ 80
bonnet $80
Radiator $ 50
Fan shroud $30
AFM $50
Standard ecu $60
Driveshafts $40 ea
Tail shaft $ 80
Front seats $ 200
Rear seats $150
Centre console $40
Speedo cluster
Glove box $30
Boss kit $ 30
Kick panles $30
Seat belts $ 200
Hey, I know this was from ages ago but it popped up in a search!
Still have the bilsteins by any chance???????
Cheers.
sunroof - condition of rubber seal around it?
rear bar - is that the reo or the stock rear bumper cover with everything attached?
  • 4 months later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
