well I dont get it then...
Ive already seen my DC at 95% and tuner says I need larger?
That comes down to many things.
Your actual rail pressure, the condition of your injectors (what they are flow matched to), the flow of your fuel pump, etc etc.
I was able to fix a similar issue in a GTR running 800cc injectors @ 300kw on a walbro by means of a fuel pump relay. DC is now 70% max.
  • Replies 182
you might have a fuel rich/safer tune then what hamish is running, that wouldnt be all of the reason why you would have such high duty cycle but it would play a part. Along with what others have said.
I'm not a fan of the bosch 040 in skylines for many reasons, but they do flow well enough. Maybe it might pay to do the direct feed re-wire/pump relay anyway :)
rewiring the fuel pump is easy with R33's or any car that has a battery in the boot. just need a relay and and decent fuse holder with some good thick wire, plenty of DIY info about it.
if you do the rewire and your worried about the tune i can throw my wideband on it and we will go for a little run and check the AFR's
i run 555cc injectors and with the same turbo/engine on e85 i make 325rwkw with a DC of 92%
you'll just squeeze in ;)
your cars a freak tho when it comes to inj d/c. most people wont be able to do that on e85
for example, my cars probably at the other end of the scale, i have the same injectors as you and run about 90-95% at around 260-280rwkw on PULP
can the settings in the ecu affect DC?
one GTR i was tuning maxed out of adjustment on the 20x20 grid while using datalogit and i couldnt get it any more power due to the lack of fuel/inj duty,
BUT
I tried something sneeky and adjusted the value's of the stock injectors to 115percent and left teh lag time at 0 and straight away i had heaps of room to tune with, gained an extra 25kw from stock inj 312.9kw stock RB26 N1 turbo's and poncams stock inj etc
weird.... what other factors can influence dc?
D/C vs power can be influenced by heaps of things including fuel type, fuel pressure, injector condition (flow and latency), richness of the tune, ignition timing (which can be influenced by size of turbos, exhaust, intake, cams etc etc) and different dynos.
89CAL, everytime i hit full load at high rpm
mine hit 100% on high boost.... have been running it like that for 2-3months now, ive got a set of sard 700s just havnt installed em yet. but it hasnt been a prob, ive been checking over the plugs after sprinted drives on high boost just to see if they changing colour at all... so far so good. tuned for 11.0afr wot so its pritty fat away
Essentially, the boost control solenoid has an open or closed position.
Closed position is controlled by gain. The higher the gain the longer the solenoid stays closed and allows the turbo to 'spool'.
Open position is controlled by duty. The higher the duty cycle the shorter time the solenoid lets boost through to the wastegate, being open allows the turbo to vent exhaust gas and drop boost.
Keeping these points in mind, a common fault in tuning is setting a high gain to acheive target boost as quickly as possible, yet have boost drop off in the higher RPM. Obviously based on the above the best way to tune would be to start with a low gain and work your way towards target boost by upping the duty cycle.
You will also see some boost controllers with a 'start boost feature', this feature is what the minimum boost should be before the soldenoid does anything at all (other than stay closed). There are also others that have a gain and boost setting, these have a map inside that calculates its own duty cycle based on pressure at the sensor.
Having one with start boost, duty and gain with limiter type correction also would be best. Not sure what the PFC has tho. With the above in mind you will probably also see the beauty in the turbotech design ;)
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
