why is it so hard
to CHAT in the RIGHT PLACE
& NOT IN THIS LIKE YOU HAVE BEEN ASKED TO,
you ask for this to be a sticky & fill it full of crap
For your information. We are discussing an upcoming thread of parts that will be put for sale, so people will be able to upgrade/modify parts on their stagea, to in fact, add a comment as to what they have done to they're Stagea "today". Also providing other places where these parts may be available.
You really need to refrain from adding your argumentitive comments as it isn't appreciated by many of the members on here. I may be new to the forums, but know a shit stirrer when I see one.
Please stop adding your opinion to our conversations.
Thanks
  • Like 1
hahaha that doesnt mean i dont have vengance for anyone else, im pretty sure you remember the last story i told you about last week. i play to hurt people haha.
if i can hurt everyone. I win :whistling:
  • Nope 1
why is it so hard
feel better now!
Edited by Jetwreck
  • Like 2
hmm.. a bit strange in here now, damn you to hell duncan. did u plan this? lolz
ps chuckie - we dont care cos we got mitchell johnson ftw. hopefully your gonna owe me fiddy and i can pick up mikes door sils.
tfif. avagoodweekend ppls. :thumbsup:
Edited by dirtyRS4
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
