Yeah, I think a drive might be a good way to unwind from work.
Hope to have a few things sorted on the car by then :happy:
Nick in his C34 should be coming, any other Sydney stags?
SAU social cruise 26th Feb
Nah - unfortunately, Raf and Alex, I won't be able to make it. Got a birthday party to attend that afternoon/night and if I come along I won't be back in time to help in the set-up.
There is a March cruise coming up though (details to be posted soon), and I should be able to make that one, depending on how many birthday parties are set up between now and then (mine and at least 5 other friends are all in March)...
Evening peeps! long time no post! Goldzilla, I apologise for not contacting you: I was down your end a couple of weeks ago, but only for a very short time, and mega busy... Hi to all the new faces! Hope all is well!
Micah
Nah: too busy trying to buy investment property, and the old girl's got some life left in her yet!
I'm trying my damndest to make the numbrs work for me to move down your way, but the pricing in the Northern beaches is........ a real Beach! Still, there is some potential.... watch this space... ;)
stag decided to start making a funny noise last 2 times i've driven it.... checked all fluid levels and everything seems to be fine!
pretty sure its the power steering belt or something....as it gets louder when I put the wheel in full lock!! >.<
(at least my clutch thrust bearing whine has gone away for the last 6 months)
might take it in for a service as the 100,000 just ticked over the other day! whistling.gif
yeh im pretty sure most cars make a slight "belty" sort of sound at full lock.. maybe get it checked if your getting someone to do the 100,000km service, maybe them??
yeah i'm getting it checked thursday!! it kindof goes away after the car warms up! >.<
just made me worried cos it was a "different" kindof a noise haha whistling.gif
lol my transmissions making a funny "different" kind of noise. sort like stepping on a cat.
im waiting till i blow it up anyway.
I thought you had said your gear box was with the shift kit was handling the new tune?
yeah I checked my fluid at the back and that's a bit low.. 99% probs the cause of it! >.<
I checked everything but the back one!
that's the atessa fluid right ? I thought a light was meant to come on and tell you if that was low??? haha
p.s. have you checked for cats in and around the engine bay ?? oh thats right.. the m35 probs couldn't fit one in there.. :P
Edited by atomaly
yeh atezza, make sure when your checking it, the car is running and at operating temp. its the only time the pump bottle will be accurate.
lol, im suprised at how modifcations fit in there.. hahaha
no cats. maybe a mouse, or two
nah turns out the atessa is fine.. had a leak near my power steering pump haha was a tad low.. fixing it up for me cos was just a clamp he thinks!!
I've been hard at work thinking about what I can keep in the back left storage thing in my car.... (the panel)
question for the day: what does everyone keep in their back left panel compartment thingy?? :)
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
