nah dont, those wheels break up the colours nicely..
a shadow chrome would look good
a shadow chrome would look crap like yours did......and going off you current choices in color ect I don't think your opinion is very well thought of! :P
Only problem with going all black is that you need something to give it some contrast!
mine werent shadow chrome you homo.
they were grey with a polished lip.
Looks the same blue as my car to my eyes (and seemingly Aaron's), has Nismo stripes and looks damn good thus the reference.
Regardless of camera trickery the body colour in that picture looks considerably more blue than the clearly silver larger second pic.
and the PM35 in the smaller pic looks silver too lol
just a slightly different colour temp
different colour temp? its a different colour dude lol maybe your slightly colour blind.
no camera trickery. it looks like your gay metallic pascal blue lol
craig you have an ARX with nismo stripes.. i dont care if your the best driver on here, the ARX is the old mans Stagea. with the vintage interior and the plastic guards.. all its missing is a horse strapped to the front lol
and thats coming from a previous ARX owner.
:nuke:
why on earth would nismo choose that colour to be the flagship nismo model for the PM35?
they commonly use silver. sometimes yellow, sometimes black. but pale blue? i find that hard to believe
open photoshop and get the colour. i dont have it with me or i would
whats wrong with gay metallic pascal blue? :whistling:
and you sold it and purchased a P platers car! I see you have now evolved into the mindset of thinking your one of the cool kids because you drive a Silviaworship.gif!
Little do you know that people don't point and look at you and say that looks awesome....they point and laugh at what a dick you look like with you hat on backwards driving on bright orange shitbox!
Basically you have set really low standards for yourself of which you have failed to achieve!
and the pic below show's what you fail to achieve when driving your jaffa!........M35 and C34 drivers have a level of coolness you will never achieve!
Oh and!!!!
BAM!!!!
Edited by Jetwreck
Oh and!!!!
BAM!!!!
Now everyone, just above you will see Mr Defensive, who is known for lifting his self esteem by putting others down. Usually a common practice of another member who he has been involved in fisticuffs with from WA.
Inow these people usually only involve themselves with the same kind, but this particular one, has moved to NSW to try and impose his attitude and try and think that he owns the best stagea in Australia.
You should steer clear from this creature, as he will try and fornicate with your children as his female mate is known not to satisfy these needs of his.
you might also hear noises from this person particularly when he is trying to make car racing sounds..
I will leave you with this image, it depicts what the majority of the worlds population think of him
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
