November Photo Thread
MaTBoY
 Share
  • Replies 317
Posted Images
Love the HDR's slim, keep it up! Totes imagined you to look like that as well!! Haha.
cheers mate :D Hope that last bit is a compliment as well?? hahah
love that poster matt, looks awesome!
ah, nice Slim, love the second one, makes the building look like its a massive lighthouse, lol
Hahah yeah it does, doesn't it. I always think of zombies when i look at the picture cos, i think its just the way the guy is walking towards the camera
the two BW ones of the girl are awesome. great smile in first one. you could throw that on a wall in the familty home. the 2nd one, looks like shes meditating. which is funny because it's such an adult serious thing to do. awesome work
yeah that's pretty much how i pictured J to look too :D thanks!
Sweet shots!
Good attempt for a first HDR. Try and setup for a proper shot and try some HDR out. I like it because it looks natural and not way over the top like most are.
As Matt said, that BW portrait looks sweet Barra! Should frame that one up!
she's a 'Ballerina'... you just ask her! haha
Sweet shots!
cheers dude... think i found some easy xmas gifts :blink:
Take a single raw shot, adjust the exposure +1/2/3 stops and -1/2/3 and merge them together. Its up to you whether you get enough dynamic range out of 1 stop, 2 stop or 3 stop.
You can use photoshop and smart objects. Open the raw folder and before you press "Open image" hold shift. This allows you to re-open the same image within the image (Instead of opening the image 3 times). Then use layer masks to put the sky in, the foreground, your subjects, whatever you want! It's how i did the rolling shots above. Love smart objects!
I use Photomatix Pro for HDR's that i have bracketed for, you can also put a single RAW file in and generate a HDR image (It will ask you how many stops you want to pull it up and down). Once combined and tone mapped, i will put it in photoshop for extra treatment.
Hope i've helped you!
Edited by FST513
Mike created me a new business logo and I simply love it. If you need logos done, be sure to get in contact with him. I think his user name on here is van? Otherwise check out his website: http://localmike.carbonmade.com/
Cant wait to print some business cards now.
Opened up a random pic from today's wedding to test out the logo (still need to figure how not to cut the bottom of the text off). Will speak to mike about that one..
Anyways.. I love big bold beautiful eyes:
Edited by siddr20
Thats a nice logo man. I like it. If you want to cut the text out, just use the marque and select only the logo, cut and paste to new layer. then delete the old one. may as well save that file as logo_notext or something.
Nice shots of the qld cruise too!
here's whats probably my last 2 from the calender shoot... maybe.
 Share
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
