  • Replies 40
Posted Images
That's what Robson does, not these guys.
Basically it is a brand new R34/S15 steering wheel that they send you and you just have to put your airbag into it (S15 or R34). The photo above is the actual R34/S15 steering wheel redone in the carbon and leather.
Just waiting on a price back for a group buy.
+1
I would be keen on this def.. Was already trying to look into getting my wheel replaced :)
Phil ask em if they can make the diameter of the stock wheel smaller, 350mm and increase the spacing so the wheel is closer to the driver 20-30mm.
The biggest bug bear with the stocker wheels is that they are too large and too far away. Make em smaller the feel of the car is totally different. 330mm is the ultimate, but not 'legal'.
Yeah I know what you mean. I find them to big aswell. But I don't think they do anything along those lines since they just use a stock wheel and do the carbon/leather onto it.
I'll ask them plenty of questions as soon as they respond to my email.
Pretty damn excited to see where this is going. The stock 34 wheel is starting to rip and tear at the moment, so I'm looking into a replacement. It's either this custom wheel, or something like a nardi wheel with a boss kit. Keep me updated on the GB + price
Damm, well if its to hard to do a group buy I will prob still be interested in Buying one off them direct. If you can PM me the details if this does not go through... Thanks again, must get so frustrating when you try and ORG group buys and the suppliers stuff around. But figured this would be pretty straight forward considering we are just buying the wheels already made.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
