  • Replies 181
Photo's on previous page
front pipes $60
sunvisors SOLD
interior mirror $20: SOLD
interior lights $20
dash loom $60
interior carpet $40
boot carpet $60: SOLD
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover SOLD
speedo 140,xxxk's $30
rear end, brakes etc. everything there $700 Buyer organises postage
intercooler mesh SOLD
trust pod filters x 2, $50
monster tacho with shift light $50: SOLD
steering wheel (310mm) $30
GTR fuel pump exc. working order SOLD
glovebox $30: SOLD
HICAS computer $40 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $30
boot release with fuel flap popper SOLD
side mirrors $30 each
bonnet squirters $20 SOLD
bonnet heatshield $40
A,B,C pillars
clutch master $40: SOLD
brake booster SOLD
clutch slave cylinder $30
accelorator with cable $30 brake and clutch pedals $20 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $30: SOLD
overflow and washer bottles $15 each
kickpanels $20 each
cooler piping one side $20
wheelnuts full set SOLD
rear passenger seatbelt $20
rearseat in mint condition SOLD
boot rubber seal perfect cond. $20
drivers door window/mirror control $40
rb20 crossover piping $20
turbo timer exc. working order $30: SOLD
handbrake $20
random 8 inch subwoofer never been used $10
Drivers side reverse light: SOLD
door sills that say skyline $20 each
timber wheel well cover $30
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray. SOLD
Front cradle is there still, hubs etc.
input shaft $50
centre console no lid $30
rear bar, haggard suit drift pig. SOLD
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel $20
C Spanners x 2 $30
tailshaft $70
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
battery clamp $10
engine mount $10
upper control arms $50
left and right cv with knuckles $80 a side
rear pod/ side skirt SOLD
Front Diff???? ta
PM coming ur way
Speedo cluster and both GT badges SOLD :thumbsup:
Also whoever was asking about top radiator mounts (can't remember who) i do have them. found them this morning :cheers:
front pipes $60
sunvisors SOLD
interior lights $20
dash loom $60
interior carpet $40
speedo 140,xxxk's $30 SOLD
rear end, brakes etc. everything there $700 Buyer organises postage SOLD
glovebox $30: SOLD
A,B,C pillars
brake booster SOLD
overflow and washer bottles $15 each overflow SOLD washer available still
kickpanels $20 each
handbrake $20
timber wheel well cover $30 SOLD
gearbox mount $50
car loom
input shaft $50 SOLD
rear boot trim SOLD
GT badges $10 each SOLD
fuel flap $10
space saver wheel $20 SOLD
C Spanners x 2 $30
tailshaft $70
battery clamp $10
engine mount $10
left and right cv with knuckles $80 a side SOLD
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
