  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
"Hey ive got a 1935 membership badge was wondering if the club would liek to buy it off me" LOL stoopid questions
my boss congratulated me for making it thru the day which was mightily nice of him :)
hahahahaha 1935 membership badge for what club :Oops:
:spew: ok for ur boss to say that u must be really sick well thats very nice of him to say that :Oops:
yup jsut hung in there today :)
I work for a horse racing club ...... horsie people are weird :looney:
ah come here u I will make ya feel better nice back rub & massage & a hot shower will fix ya right up :Oops:
ah ok cool why r horsie ppl weird ??
This is regarding the hinze dam/ coast cruise that happened on the 26th. Cheers.
hey guys. what happened yesterday? you guys were drivin like a bunch of maniacs! it was expected though. after hinze dam you lost a couple of us at the back(got stuck behind an ass in a terios that was really ****ing me off, and he was doing it deliberately.) and we kinda missed the turn off back to the coast. we ended up going for a pleasant cruise all the way down through the ranges and ending up way across the border into mexico and somewhere around in the midst of ballina. ( gasp; this is a ****in long way into NSW). fair enough it was our fault we didn't take the turn off but yeah would like to have taken a few more pics of some moving cars. what time did you guys leave the spit? we ende up getting there at about 3:30 after the extra 200k trudge down through mexico. it was a good drive though i must admit. except for some scary mountain bogans who almost sent me off the side of the cliff a few times. could be a nice cruise some other time.
any ways. i do recommend that if any one organise a cruise or come along on one that they invest in a UHF radio. if you can afford a skyline i am sure you can spend a hundred bucks on a radio ****in.
nice pics mrstagea. your car was "fully sick" for use of bette words. it was a very nice piece of nissan i must say.
PS. if any one knows a contact no., email adress or some way i can contact the guy with the muscles that drove the crazy r32 with the dark purple bonnet with the asian characters down it please let me know as we were discussing some gear i would like to purchase off him.
hope to go on another cruise as soon as possible guys and will always be up for them.
peice out to myr32.
hope to see you at the next cruise guys. cheers. Brad( Black 93 r32 gts-t.)
[email protected]
Cheers!
BHAHh ah HAHh HAh HA hhAH hAH haaa
Sounds like your typical SAU Organised cruise!! :P
And they call us organised, he heheh hBH ABHb hAHB AH B hAHbAHBHAHA HAh h H ahAaaaa!! :)
By the looks of the pics it seems it was a good turnout and a nice day for a cruise too! :D
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
