  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
my sprint car friend has a 2004 f250 (7.3l turb V8) with a 5in zorst and a power chip it does 14.3 1/4
OMFG
not bad for a heavy bitch of a car :P
Wonders if he can fit the engine in the R33
