  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
rofl IBuM and werk just had a quick celebration of their shitty servers still running for last 10yrs... FYI a P3 or P4 would out perform it over and over...
http://www2.qpsf.edu.au/maintenance/hardware.html
hey will.. do you have GTS-T brakes still on your GTS-T / R ??
Wouldn't happen to have any photos of the brake setup would you with the wheel off, especially around the back of the caliper?
Maybe if you have a spare moment you can stick your camera behind there? :P I need a photo..
some.. see its all "planning", working out in my head first, project plans.. :)
problem is its wrong project :P
hehe.. nah, i been working at the other place 3 days a week, which is enough pay for the week.. the other main project can be delayed a bit :rant:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
