F5
hahaha
yeh old wasteland was closed but was supposed to be re-opened but meh it didnt happin
hmm so hot today. and i gotta work soon :cheers:
wonder if we will get storms like last time
lalalala too quiet in here im gettin food
WHORE :aroused:
heheh!
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hahaha, now i can see how it got out of control last time.. but oh well - bring it on!!
Got rejected for another job this morning :)
I wish to advise that following the selection criteria you were unsuccessful in your application for PHP programmer
I mean WTF? Selection criteria? My skills and experience matched everything they put in their ad and yet I still got rejected :D I've had about 2 years PHP programming experience, and this isn't enough?! wrote back a response 'cause i wasn't happy, fug em :cheers:
i'm getting sick of this, I just want money so I can mod up my car, and get rid of the stupid silver and grey side I gotta drive around with.
Yeah I saw that story on the news too.
I think it has been done many times before at different places with success. I seem to remember them trialing it at a shopping centre that was rife with street kids and it got rid of them fairly quickly.
The reason the first thread was deleted (or so we are lead to believe) was because people were using it for total and utter trash, just writing F5 and just putting smiley faces. At least some of the other states wastelands actually have content worth reading.
I'm sure if we keep this thread on the right track it wont get deleted
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
