  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
What was the exchange rate like when they were new?
Ahhh good point.
probably would have been about 45-50K which seems about the right price for a car like a GTST.
35K seemed a little low.
no idea smooth :D I got my bar from Jetspeed in melb. Its so hard to get original stuff or something different. try DMD
Otherwise if you have the money speak to Rezz, he should be able to speak to some people in Japan and source you one. Won't be cheap I wouldn't imagine, but may be able to get an original.
It sucks when you want to be different you have to pay much more. All the stuff that jetspeed had looked pretty hideous, or cost a bit more, so at the time just went for the 400R because it was there and still looks good.
Is this similar to yours??
Just had a thought which occured to me whilst in another thread,
I think QLD has only one moderator at the moment, I mean check this out......
Squizz: Last post..... 11-12-2003, 02:36 PM
Birty: Last post ............ 11-09-2003, 09:45 PM
BOOSTMEISTER can't be the only one left can he?
Maybe a couple of job openings for those responsible post whores amongst us :Pimp2:
kinda funny.. not that you really need a stack of moderators though unless there are a heap of posts though. Wasn't Squizz moving, or had moved down to Brisbane or something ?? That was the last i saw of him.
Bit pointless to have mods that never come on, but i'm sure that will be sorted out eventually.
Moderation, well I think we dont really need it at the moment, but if we have to then yeah I'd choose strutto, NismoGirl, Pred or Nexus9, as they all seem to have been here for a long time, and they are pretty sane :D
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
