not 100% on exh side AR... its the 8cm2 i am running at the moment. And i dunno where the post is, but i think it was by Steve, he showed a comparison table that related cm2 to AR
Reason for selling: Building an RB30DET and this ---->
is sitting next to me :P
EDIT:
3" i think exhaust
600x270x55 FMIC
EMS Dual Sport ECU
stock!!! injectors
550hp fuel pump
Stock fuel pressure
Stock engine internals
2.25" intercooler piping
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well assuming its on an RB20det right now and will bolt straight on...
you will need to block the water feed (comes from inlet side around the back of the head via metal tubing) and water return in the block.
Once that is done a tune would be very wise!
Then once that is done you will notice a big grin on your face :P R32's are MUCH lighter than my car ;) And with the power i got my car gets up and boogies all over the road on boost... well used to, brand new 255's have calmed that a fair bit.
But cuz i bought my turbo from a guy who already had it on an R32 RB20, all i did was unbolt my stocker, plug up the water lines, bolt new turbo on, then drove around with the old tune for 2-3 weeks before i got it tuned.
i did get the dump pipe modified to suit my car etc. Which you will need a custom dump pipe by the sounds of it
Pred, the rb20 turbo is classed as a non good turbo.
lol :P maybe, but then again they were designed to be cheap to make and give 165kw or whatever the stock R32 power output is ;) So they do that. Just like the stockie RB25 turbo isn't great either..
wish i had the funds for an 2530 myself. Probably what i would go for -- not after big dyno figures.
Skyrine-Dave : watchout.. might chew up that phone...mmm.. RB30 + big ass turbos :)
Predator: It can chew that fone.. well try! its lasted many drunken nites in town... read: Dropped all over the place :P good old 3210 reliability :)
I did want a 2530, but being a tight ass uni student didnt really allow for it. I previously had a hi-flowed R32 turbo and that sucked so much ass its not funny. Sure the car was powerful... compared to my old V8 Fairlane 500 (god bless it ;))... but it sucked none the less.
As i see it. The 2530 sounds like a very nice turbo for an Rb20, but not having been in a car with one on it... i cannot comment. Tho i've seen some Rb25 owners not happy with 2530's due to their extra capacity.
yeah.. heard that - HKS 2530 will only give 230rwkw or so on an RB25DET. Apparently though its meant to spin up quicker than the stocker and give you a bootfull of midrange which sounds nice. Keeps the engine nice and safe anyhow.
anyhow, i'm off..later all.
Dave - so running it on the stock engine and stock cooler would be fine? at 7 psi?
whats the lag like .. doesnt get on boost to 5 grand or something?
is turbo lag a good or a bad thing?
oh man! stock cooler... i wouldnt bother. With my hi-flow i had so many over heating issues with my stock cooler!!!
FMIC at the same time or before... or ASAP once you install it. makes a huge difference... i went from 47deg inlet temps to 25deg inlet temps!
Turbo lag... hmm u can drive around casual just makin spool noise but not coming on boost, just goin all casual and quiet around the streets... but mash ya foot to the floor... 4000rpm and all hell breaks loose...
i like the lag so i dont have to drive on boost all the time. as the car is daily driven.
Personal preference really. The only time i kick myself is when i'm in the wrong gear and have 2000rpm before decent boost kicks in when having a "roll on"... problem solvered by dropping it back a gear... or 2 and away you go.
OK here's the deal the $5 do not have plastic covers and have really been used and show it, all the pages are in and not looking at falling out, but you can tell they've been heavily used. The $10 are from here in the office and are perfect other than the plastic is faded.
These are also for sale to anyone inside the company so dont know how much longer they will be there for, but we did have about 30 to start with so guess whoever wanted one has one by now, but yeah dont know how much longer I'll be able to get them for.
$5
1.
2.
$10
1. Nexus9
2.
Alright last chance anyone want a cheap UBD, going, going..............
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
