  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i just clicked on the pillow on the bed lots and the steel rod fell out.. or else i clicked in a special area
for the ppl who have completed it... reckon its possible to do that thing after the movie straight away and escape ?
