  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah but our users have plans and layouts and all sorts of other crap on their desks, the last thing they need is cables crowding up the place, cordless is great and the logitech are awesome, but of course magaement saw the microcrap ones were $10 each cheaper, save $100 and pay me a frig load more for trying to get them to be less powerful, go to the point of putting deadened batteries so that one user does not accidentally move the mouse on his next door neighbours computer! :D
where is your office ska? me pictures myself having a little fun out the front with an orphan desktop keyboard and mouse :D
it would be like a phantom interference on your pc and it was possessed by a spirit or something. Actually that could be kinda freaky!
chaos: yeah, there are viruses out that almost do similar. Install a trojan on your machine, then later they can get in via IRC and control all their little army of "slave" PC's to do their bidding. Kind of insidious actually.
Or the old fashioned "back orifice"
Byron? just chill out and spark up a J... :D
Im so over my current job, its good in so many ways, but there comes a time when you have to think about the big picture.... :rofl:
wana go bigger matty!! ive done my homework, damn coldwell are big! ask for a job in the states with em?
I could go to the states, but i have never wanted to live there.
Sure they are big, but it doesnt mean they will work here and now.... maybe in 12-18 months, but i have things to do NOW :D
Its been a shit day
/end rant..
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
