  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah oh well So Glenn, who's turn is it for next week, hey what about you PhatMirage, I remember you not minding organising something for next week, you still up for it?
(check my palm-top) its Team Gold Coast's turn next week issit it :(
i reckon its best we split the pack up into smaller groups. say we have about 20 cars or so and the leader/organiser picks/nominate 3 other drivers to lead smaller packs of maybe 5-8 cars.
was brainstorming last night at the shed and realised that i should have pick at least 2 other guys to lead as well so that everyone can arrive safely at the destination albeit in different time.
juz an idea.
(check my palm-top) its Team Gold Coast's turn next week issit it :)
juz an idea.
Yeah thought about that one too, but then it just involved too much effort for me to get up off my lazy ass and ask 4-5 other people, which is why I thought the "buddy" system works good, plus radios, and hey presto, even though we went through about a million sets of lights and still could not hear you on the radio, we still all made it there in one piece!
Organising 4-5 other "leaders" and breaking up the pack is a good idea, if you could be bothered and if you could find 4-5 people to do it. But then you'd have a lot of chatter on the radio on who is at the back of which group turning where and maybe a bit confsing, Just have someone right at the back with a decent radio and who makes sure no one gets left behind, a job I thought I did pretty well with the help of Erin, prolly without her, it would have made my job harder as my plea's for directions and updates on where to turn where and asking everyone to slow up _might_ have gone unoticed :D
Key points:
1. Always keep a skyline in your rearveiw mirror
2. Always have someone appointed last in the queue, with a radio who knows where to go and can call out to someone in the pack who is listening to slow down or ask for directions.
Easy peasy!
Yep... Well done Ska and NismoGirl...
Guess what Ska? You just nominated yourself for last in the pack at every cruise... :)
You clearly can't handle the pressure at the front!!! :devfu:
Yeah I dont mind, I am looking at buying a in car though, want the range, and a guy here at work seems to think he can get a deal on them, so might do a group buy if anyone else is interested.
NismoGirl what type of antennae have you got, I had a look at PhatMirage's and it's pretty cool, dunno if I really want one of those big ass areials hanging off the bonnet, but guess the bigger it is the better the range........but at what cost :D
Yeah I dont mind being last, just as long as someone listens to me when I call out to slow down I am more than happy to follow :D
Bloody hell it's been a crap day, and I am still at friggin work, BAH time to go home and whore from there!! :D
afternoon...
i was looking at my rims trying to figure out what size thet are, they have r16's on it .. and i was thinking that it was a 15" rim and not 16"
but when i measured it it came to 17"
im like wtf? .. did i stuff up on my maths .. this is what the tape measure reads..
400
1ft 5
John, yeah lots of coffe works well as i have "management training" on fridays, so I had hmmm lets see, bout 11 cups of strong coffe now i am ALL HEPPED UP AND RARING TO GO! but got nothin to do....... and wtf is harry's mindflux?
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
