I'm with you on the lunch truck ska.  The last thing I bought from the Salmonella van was a sausage roll, and it was pink on the inside.  I spat out the mouthful I was eating and threw it out.  I mean WTF?  How do you get a sausage roll to be pink on the inside.  I don't want to even think about it.  Well, I'm never buying anything from that truck again.
hehe.... *girlish giggling
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
usually i would agree if it was one of those vans that sold Chico rolls, pies and sausage rolls, but this dude has freshly made rolls with stuff like fresh smoked salmon with capers and shit like that
and the coffee mmmmmmmmmmm
Mindflux, the reason I didn't guess your last sig was that It was an aqua song. Hmm I wonder whether those guys sit around and wonder what happened to their careers. Also where was my invite for the impromptu cruise or rather crawl on friday???
It doesn't really bother me because I had to be at na_r33's house at 6:40am the next morning and he looked very ordinary after only a couple of hours sleep.
*** Semi Urgent ***
Aight, those of you who know about my recent gearbox problem, ive decided that i'm going to change the oil and run some readline threw it to hopefully fix the problems..
However i've never changed transmission oil, so is there anything i need ?
my bro tells me i need a pump
Probably sitting around counting their money and laughing at the fools who paid for the rubbish they released.
*** Semi Urgent ***
There is a guide in the diy section, the hand pump it to pump the new oil into the gearbox, looks preety simple to me, yet I have enevr attempted it before, but looks preety easy, even you could do it :D you have taken apart every other bit of your car :) jk
Yeah for a person who got their parents to buy the car for him, he treats it execptionally well, well everytime he has been cruising with me, but hear rumors to the contrary about that, but I will only base my depiction on what I have seen and he seems to be a very "grandmaish driver, needs to learn not to follow so close, made me very very very nervous a couple of times on friday night :rofl:
Predator - what you looking for?
Theres this chop on the goldcoast called someting 'Customs' he does all mini trucks and that, awsome guy when i spoke to him .. only seen him once, was waiting got my mate at a work shop near by and i saw this mini truck and stopped to look, and he came out showed me how the bags work .. showed me hsi other cars and his big plans etc
I think its called 'Karters Kustoms'
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
