I'm with you on the lunch truck ska.  The last thing I bought from the Salmonella van was a sausage roll, and it was pink on the inside.  I spat out the mouthful I was eating and threw it out.  I mean WTF?  How do you get a sausage roll to be pink on the inside.  I don't want to even think about it.  Well, I'm never buying anything from that truck again.
hehe.... *girlish giggling
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
usually i would agree if it was one of those vans that sold Chico rolls, pies and sausage rolls, but this dude has freshly made rolls with stuff like fresh smoked salmon with capers and shit like that
and the coffee mmmmmmmmmmm
Mindflux, the reason I didn't guess your last sig was that It was an aqua song. Hmm I wonder whether those guys sit around and wonder what happened to their careers. Also where was my invite for the impromptu cruise or rather crawl on friday???
It doesn't really bother me because I had to be at na_r33's house at 6:40am the next morning and he looked very ordinary after only a couple of hours sleep.
*** Semi Urgent ***
Aight, those of you who know about my recent gearbox problem, ive decided that i'm going to change the oil and run some readline threw it to hopefully fix the problems..
However i've never changed transmission oil, so is there anything i need ?
my bro tells me i need a pump
Probably sitting around counting their money and laughing at the fools who paid for the rubbish they released.
*** Semi Urgent ***
There is a guide in the diy section, the hand pump it to pump the new oil into the gearbox, looks preety simple to me, yet I have enevr attempted it before, but looks preety easy, even you could do it :D you have taken apart every other bit of your car :) jk
Yeah for a person who got their parents to buy the car for him, he treats it execptionally well, well everytime he has been cruising with me, but hear rumors to the contrary about that, but I will only base my depiction on what I have seen and he seems to be a very "grandmaish driver, needs to learn not to follow so close, made me very very very nervous a couple of times on friday night :rofl:
Predator - what you looking for?
Theres this chop on the goldcoast called someting 'Customs' he does all mini trucks and that, awsome guy when i spoke to him .. only seen him once, was waiting got my mate at a work shop near by and i saw this mini truck and stopped to look, and he came out showed me how the bags work .. showed me hsi other cars and his big plans etc
I think its called 'Karters Kustoms'
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
