  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
if you want a good laugh get on your mates pc , download some gay porn , then delete it and he will end up getting gay porn adds poping up all the time , so you can sit back and laugh and call him a little poofy boy
