  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
adrian: i can provide basic directions from NGC to that shopping centre point .. i think it should be good. Never been that way myself which is a bit scary.. but it all came to me on the map the loop :)
I think we will be right Gordo... I've been out that way before to help out some fellow sedan owners...
Not gunna nerd it up with Pred here and get into an argument over it but I'll add the following...
IP address - Internet Protocol.. basically every computer has one of these addresses..
There are public and private addresses... Every device on the internet or in a TCP/IP network has one...
TCP - Transmission Control Protocol - form of sending stuff over the internet
Tick... All TCP/IP networks use TCP to send information between devices...
Packet - small block of information sent via TCP
Or other network protocols...
Browser - you're looking at one
Yep... the bit that displays the HTML...
HTML - hypertext markup language. Using basic text language plus special tags to designate the text and make it appear different (the markup).
Not gunna argue with master...
JPEG - Graphic, damn forget what it is.. i learned it in uni :)
Joint Photographic Experts Group... A form of picture compression to shrink the size of a picture to make it less demanding on bandwidth...
MP3 - Multiplexed sound (i think).. basically encoding sound so the bits that are drowned out by high volumes straight after are thrown away as they are inaudible anyhow.
MPEG1 Layer 3... Preds description is correct... A form of audio compression to shrink the size of a sound to make it less demanding on bandwidth...
Bandwidth.. bah.. my brain just broke :D
The amount of traffic a network can carry for a given amount of time...
Oh, and google will be most helpful if you need more detail...
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
