  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
my bad. ska.
So did you get chewed out this morning like you thought you would?
Yupp, not as bad, but still not good, own fault, SAU is my fatal weakness, but yeah had the top 4 managers give me a serve.
Nothin to do but block SAU during day,
