  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Definately the assignments, just looking at the requirements for this report I have to do tonight makes me want to go out.  Anyone?
why do you have to pick this time to go out when i have a 3 hrs long lecture coming up :D
give james or tze a call ... see what they got plans for :D
Jason,
Before I forget please accept my most heartfelt apoligies for going all 4wd last thursday when the GTR was behind my car.  When glen told me I did that I felt sooooooo bad. :D
Its all good, no stone chips, no problems. It was kinda in the danger zone, rocks flying and cars nearly getting reversed into it. It was more because of the situation than anything else.
I think that was the lesson of the evening. A gtst with a front mount is definately not a gtr. Thanks for not being mad.
cmon all you guys were whinging because nothing is organised for this week, suddenly i organise something and no one registers their interest!
build it and they will come :D
personally I dont give a **** where, when or how far...just tell me where to be and when....
sorry ska, was trying to flatten out my hair getting ready for my lecture.
i am definitely in... and you can also count in the regulars as well.... but dun expect the unexpected :D
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
