i would of fitted it for you! did like 10 of them while at Gilmour, and yes there are shit loads of wires! you should try wiring up a remote start! got told to do it and had to work it out all by myself, learned how to hot wire imobilised skylines and 300zeds in the process not that i would ever put ne of that to use...
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Serious, oh well, too late now.
of course i would have had to borrow it for a week just to make sure it was all working properly.. haha
mmmm, yes. :slap:
next time i see you on a cruise JL i will hit you up to take me on a little run round the block or something :D
No worries.
I am really struggling here.  I have taken today off work to do assignments and there is a guy here fitting an alarm/immobiliser to the R, so naturally I am distracted.  I can't believe the amount of wires that go into a security system for the car.  Its huge.
freelance fitter?
1.0 How I Got My GTRs
2.0 Brief Discussion on Horsepowers
3.0 Plans For The Future
4.0 Lend Glenn For A Week
Now it you can just tell me how to work that into Assign 1 "Observation of Precise Horizontal Angles" we will be onto a winner.
EDIT: Hang on you need an extra one
5.0 ramafications of lending to Glenn for a week.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
