  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
What happend to nick> was there an incident???
matt, no worries. nick's fine. i'm just telling Chao to get use to the skyline first before attempting any mods on it.
nick farked his car becos his tyres were not road-worthy, whereas he should have gotten new ones asap.
Nice, thanks
What did you get?
i had problems fitting in the front aftermarket sway bar becos of the tight bolts so i rang them up at 11am and got a spot at 4pm + a wheel alignment as well :D
How long did they take?
1 hour. Check in @ 4pm and out @ 5pm sharp.
I basically want to get everything thats beneficial that i can, besides springs and shocks cos i already got them :)
i reckon half a day. The guys love taking smoking breakies :D
got about $1200 to spend
did you goto the morooka fulcrum genesis?
yup, i did. guys there are friendly but labour farking expensive but i am sure you knew that already. :(
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
