  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
chris... how long you gunna keep you signature? ;) .. everyone's changing theirs... heck... Cyrus changing it almost like his underwear...
actually I have been toying with the idea recently, but then all the new people will miss out on seeing my Canyonero song
and I am fairly sure he changes his signature more then his underwear ;)
funniest thing on the way back to bris, traffic control dude in his ute with all his signs wanted to race me so i raced him and he found out what channel we were on on the uhf's and had a bit of a chat before flashing his orange lights turning off and wishing us a good night then an oldschool pulsar tried to have a go? i mean really......
speaking of me .. here i am!
Man ive decided, next week will possibly be my last SAU cruise..
cruising puts to much wear on my car. and i have some self controll issues to deal with before i can drive on a cruise again :S
WAs fun .. you gys missed some of my best work tonight .. not no where not talking about ont he mountains
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
