  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Were you the chick with glasses or something and i was explaining the interior of 61rly too?
Nope. Black skirt, black jacket, black top, black bag (geezz, i musta been lookin kinda evil hey..) dark hair.
you actually turned your back on me at one point, you were talking to james and stood right inbetween us with your back to me. Was quite rude. but oh well.
sam - hey sorry, i was just running up and down like a mad man as i had so much running through my head i had the chase up people to get money, had to chase people to give money .. had to find everyone .. and had to meet new people.. not to mention a certain female passanger of mine and me were havign arguments over nothing (shiit im famous for that) .. yeah i was just runnign about and i lost track of myself a few times.
deeply sorry about being so rude .. maybe next time eh?
matt - yeah everything is semi sorted.. i gotta head up there in the enxt few days to pick up the stuff, and yeah..
been kinda busy latley .. been spending huge amounts of money .. now im broke and the defects put me in to dept today .. hopefully i can get my licence back out of it too :)
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
