  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Nick can you like message that chick you were with and say
'hey you know my friend with the white owl you spoke to the other night, he wants to know if your single'
help a brother plzzz
sorry man, as much as i'd love to help a brother.... she aint lookin..... besides, u really dont want to go there man.... TRUST me
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
