its a good idea to replace the tensioners.. was yours stuffed cyrus or he just thought it was a good idea?
mine i am not keeping much longer so i don't really care about longterm viability so much.. as long as it doesn't pack it in in the next 10,000km thats all i want. .
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
So I have to scan them?
well i scanned each page in off the refidex.. then imported into photoshop, matched, resized.. etc
Oh MAN why not just use the UBD on cdrom, dats whay I do :), way eiser than scanning!
Well one is stuffed and Gav said it owuld be best to replace both at same time, I still have both of them, I thought hell I have paid for them, mine as well kepp em, might bring them along next time I am out :D
Cyrus, congrats, ur now in charge of sending me the maps off your CD :D
you got broadband I'll just email you the cd :D:)
I can post on to you if you want, they are only like $30 and this new version you get all the cities, even perth! :D
There's not point using map references because every refidex's pages are different.
Are they? I thought they at least tried to keep the same ones as best they could. UBD always did suck though.. nobody used them in melb - they all used melways.
CD rom sounds like the best way!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
