  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
and nicole messages again
You are the only guy I have ever met who winges when a girl is chasing you up and not the other way around! :D
how do you put a pick in your sig , I just get ?????????
Stuffs me I just upload it to my webserver then link it back using that insert image button :(
yup.... funny thing is.... learnt a few things about my car..... wrong plugs..... brakes meed fixing.... hmmmmm and what is that bp ultimate fragrance in my cabin.....sniff sniff
Didnt you just get your plugs changed by gordo at the caliper painting day a couple weeks ago?
And I get that petrol smell in the cabin a lot too, seems it is a dodgy seal somewhere I havent bothered to fix it as I think I'm used to it now, doesnt seem to bother me much, I get a lovely euforic feeling everytime I drive for some reason........ :D
Well I have to go ppls , gunna keep scrubing down my rims . at least I should be able to get them painted sometime this YEAR ........ !!!!!!! if anyone can give us a lift for the thing today , I have fuel money and am on the GC , call 0402220733 !!
Morning lads.  Sounds like you are having a few car issues there Nick.
Yeh mate, i guess its the inexperience and rushed decision with the car.... its running alright now but the spark plugs are wrong so in a few weeks its booked for a full service and a dyno tune
edit: fuel pump died
Don't worry, one of the first lessons learned when you start messing around with car is :- its nothing that can't be fixed with the injection of large sums of money.
In fact you can apply that to many things.
hi everyone and hi chris havent seen ya in a while, hows things?
Hey matt,
yeah been on the down low for the last couple of weeks.
Probably still will be until I can get a few issues sorted out unfortunately
you taking it to Gav's?
